Teste drive Peugeot 106 electric (um antigo carro do futuro)
Temas relacionados com automóveis elétricos
  • Fantástico, vou seguir este tópico atentamente
    Uma pergunta:
    Ja testaste se o pack não ira precisar de arrefecimento nos dias de verão em solicitações pesadas ?
  • Carregamento rapido com gerador
    Gostei deste artigo, vejam para ver se podemos retirar algum sumo:
    http://www.evguide.nu/1128km.html
    ----> desculpem por não ter tido paciencia para traduzir, mas le-se muito bem:
    Conclusion
    - Yes it is possible to drive long distances in a battery electric vehicle.
    - The Battery electrical vehicle is capable of doing long distance travels
    if it has 3 phase power for charging. This should be an integrated part of the car instead of being an extra unit taking space in the boot.
    - A charging time of 1½ hours is bearable time to wait. With the cars
    own charger the charging time would have been app. 5 h/charge!
    - The access to 3 phase power is possible in most service
    stations during work hours. The red round 5 pin 16 A CEE socket
    should have been on the outside of all service stations, so the access
    to them is also possible in the evenings and weekends. Today there
    are locked in outside work hours.
    - Continually driving/charging can make over 30 km/h in average. Single
    phase charging makes app. 15 km/h!
    - The car has not fully motorway performance. With 1.300 kg total
    weight and 20 kW engine the power to weight ratio (15 kW/Ton) is
    inferior for motorway use. 25-30% power more would have been
    appropriate.
    - The max speed of 90-95 km/h, which this car can do, is also slightly
    inferior. Just 5 km/h more would make a difference.
    - The energy capacity of 12 kWh of the battery is OK. It is sufficiently
    for 100 km in summer and 80 km in winter.
    - The electric car can make good autonomy (range between charging) in
    both hilly terrain and on motorways.
    Se neste caso os 12kwh são para 80 a 100 (inverno e verão) os 17kwh, segundo estas contas testadas neste 106 eletrico pode dar para 110 (inverno) a 140 (verao)
    rocker_pt
  • MRider Escreveu:Ja testaste se o pack não ira precisar de arrefecimento nos dias de verão em solicitações pesadas ?
    O carro não foi feito para grandes correrias, e nas mãos de quem está, poderia até ter apenas metade da capacidade que ainda assim não seria grande solicitação para as baterias. Mas claro que assim, para além de promover maior autonomia, também será menor o esforço e por sua vez quase nulo aquecimento.
    rocker_pt Escreveu:Se neste caso os 12kwh são para 80 a 100 (inverno e verão) os 17kwh, segundo estas contas testadas neste 106 eletrico pode dar para 110 (inverno) a 140 (verao)
    Penso não fazer tanta diferença entre Inverno e Verão. Gostava mesmo que pudesse fazer os 140Km! :)
  • Como se esta a portar a máquina Jorge??
  • A maquina é uma maquina! :lol:
    Anda que se farta, e sem passar dos 95Km/h.
    A 75Km/h gasta 50A. Já daria uns bons kms com os 120Ah.
    Só falta mesmo testar a autonomia, mas isso será quando tiver BMS de protecção.
  • Como está mais leve deve ter um melhor desempenho.
    Uns vídeos ajudavam hehe
  • Quando colocas aqui uns vídeos da condução do Peugeot?
    Ainda se porta bem?
    ICEM4N - Predator 40.000km
  • O carro porta-se muito bem!
    Já leva com mais de 10.000Km desde a primeira vez que o conduzi. Tem despertado o interesse de muitas pessoas, pela sua facilidade de condução e manutenção reduzida. Algumas também se preocupam com o meio-ambiente!!
Voltar para Automóveis
