Ou compreendi mal ou não leram o tópico do ES (Endless Sphere forum) com cuidado:
Isto foi retirado do texto original no link indicado acima.
(...) The other feature I thought people would really like is a second throttle input that does variable regen. They agreed to add these features and I have been testing them for the last 1.5 weeks since I received a batch of their controllers. The variable regen works very well from 0 to almost locking up the rear tire if you set it high enough. It's only enabled when you activate the brake switch. This allows you to use a low level slip charge for normal riding which I've found greatly improves my regen, but when you press the brake button you can coast like normal, or vary the amount of stopping force that regen is providing :)
The hardware works great, but they need to update the software to allow more flexibility in the variable regen and motor temperature protection settings. I just emailed them tonight and let them know the variable regen works as expected and suggested some improvements to the programming software. The software has not been updated to handle these new features since they only developed them last month at my personal request which was very awesome of them to do. (...)
Pode ser programada uma combinação complexa simultânea de vários tipos de e-brake:
1. Um valor fixo baixo no deslize quando se solta o acelerador
2. Um valor fixo quando se usam as manetes de travão
3. Aumentar este último valor fixo com o acelerador esquerdo
Alternativamente pode ser programado o facto do acelerador esquerdo controlar por completo o e-brake.
Chamo também a atenção para o resultado destes testes divulgados no mesmo tópico:
(...) Car manufacturers utilize regen while coasting because most people don't use pulse/glide in a car. I don't use it on a bicycle either. Tried both ways, button regen and slide regen. Using a button I only recovered about 3% vs 10-12% on the same commute using slip charge. This test was done a wile ago when I was still commuting by bike, but I still find those numbers to hold about the same when I go even for a low speed ride with my wife. (...)
Podemos eventualmente andar enganados quanto á utilidade do slip charge.
Editado pela última vez por
MVS em 10 ago 2014, 11:30, num total de 1 vez.
