Este método só funciona para a roda da frente:
https://www.youtube.com/watch?v=CnkFgjI9Cxohttps://www.youtube.com/watch?v=T2AuivYzaBsComo afinar um equipamento balanceador estático barato comprado online (para a roda da frente mais uma vez):
https://www.youtube.com/watch?v=9koGE_HrTJ8Eis uma sugestão interessante para a roda traseira retirada daqui:
http://visforvoltage.org/forum/2609-balancing-rear-scooter-tire
I came up with a technique for spin balancing hub motor scooter rear wheel a while back.
1. Put the scooter on it's center stand. Make sure the rear wheel can't contact the ground.
2. Open the throttle so the rear wheel spins - look for a badly out of round or out of true tire or rim - such a tire or wheel will vibrate even if balanced.
3. if it is out of balance, there will be a certain speed where the vibration is worst - where the RPM's are resonant with the rear springs or suspension.
4. With the wheel spinning, at the worst-vibration speed, hold a marker supported on a block of wood on the floor, so if lightly brushes and marks the inside of the rim (i.e. the part over the bead) as the wheel vibrates up and down.
5. This will mark the "light spot" of the wheel - or often, about 20 degrees counter-rotation from the light spot, due to inertia and friction in the suspension.
6. Place balance weights (1/4 oz for starters), temporarily with tape, about 20 degrees in the direction of rotation from the mark - same amount both sided of the rim. (they need to be placed where they won't fly off when re spun of course).
7. Re spin and re-check per steps 3 and 4. Add weight, remove weight and move weights around the rim circumference as needed until the wheel spins without vibration. Place weights equally on each side of the rim centerline to prevent creating a bad dynamic imbalance.
8. Take your time, It usually takes some patience.Um aparte também relevante do M. Chen:
Robert,try to deflat the rear tyre first.
Then adjust the right angle and position between rim and tyre before inflat again.My engineer said that is the position problem which might cause the vibration.Eu optaria por começar pela sugestão do M. Chen e testar várias posições angulares (de 45 em 45 graus) do pneu traseiro na jante. Ficar com a melhor. Se a vibração resultante for aceitável ficar por aqui caso contrário prosseguir para o método anterior de colocação de pesos.
Em alguns bons pneus a zona mais leve do pneu vem marcada de fabrica a amarelo e deve ser alinhada na montagem do pneu com a zona da valvula para que a mesma não prejudique a distribuição uniforme do peso ao longo da circunfrencia da roda.
